Hi guys,
As promised, today was my turn to try the tin foil hat solution. I can concur that it works. Kudos to
@HOWIE13 who originally thought of the tin foil wrap.
Still, I don't go the lengths
@mordy did with wrapping the whole tube. Instead I started off immediately with wrapping the anode cable and trying to simulate the pinching effect. I also experimented with grounding, as per
@pctazhp's suggestion. Oddly enough any attempts to touch ground failed to reduce the humming. Instead, leaving the ground wire hanging in the air seems to work fine, albeit I have to [re]position according to the tubes I'm using (see below)! Finally, using tin foil on the anode wire without some sort of 'pinching effect' didn't work: looks like the latter is an important part of the equation.
So far I've only tried the 12spez as powers. My initial experiments were with the EL12n as drivers. When I substituted the latter for the RFT EL11 I had to move the 'ground' cable to a different position to get rid of the humming.
The sound of the TFK EL12spez is indeed dynamic. Clear separation and black background are also characteristic parts of the sound signature, but I'd say the most pronounced part is its 'energy', as so many of you seem to agree. Combined with the EL12n as drivers, the sound was darker; whereas combined with the EL11, the sound was [actually,
is—I'm still listening to this combo] brighter and more resolving. Listening to the La La Land score, which is my—as of lately—go–to music for rhythmic rendering and articulated mids, they play amazingly, with great reserves of energy combined with resolution. Therefore, I certainly understand how the lot can be appealing to rhythmic tunes and analytical cans. On the other hand, listening to Bartok's Concerto for Orchestra (RCO/Chailly/Decca, same record as the Mandarin) I can hear every note clearly but I feel that their
very dynamic presentation makes them too harsh for the HD600 (e.g.
in this track the highs are hardly bearable, to my ears). If I were to summarize, I'd say the rendering is precise but quite forward in comparison to other combos. Still, I don't see myself returning to the EL12/12n combo, as I find this set to be very impressive by comparison. Perhaps I'll just switch them around from driver to power and vice versa, for the interest of science.
At this point, it makes sense to reserve these as
just my initial impressions. As
@hypnos1 said, these may benefit from burn–in; therefore I'll give them a chance to develop over the next few days. New readers should also consider that I'm neither familiar with headphones, nor tubes for that matter. My background comes from speakers and solid state amps, therefore I'm merely educating myself as I go.
As per usual, here's the photoshoot from my escapades.
For reference purposes, this is the 'pinching effect' I mentioned earlier. Namely, that my buzzing adapters stop buzzing once I pinch them on the anode wire.
Tin foil hat. Doesn't work without 'pinching'.
This works!
This also works! That's how I roll at this very moment. Notice that neither of the wires are touching anything. All my attempts to ground them produce buzzing.
Not quite at
@hypnos1's level of expertise, but getting there!
This is the EL12spez/12n combo.
And this is the EL12spez/El11 combo.
Notice how the brown cable on the left tube is moved slightly. Once I attached the EL11, my previous configuration started buzzing. Moving the left cable fixed things.
